Participant lanxiang.ben
Vivado2013.4 ILA debug error about vcse_server.exe and others
Hi All
    When I use Vivado ILA to trigger wave,then appearance as follow,and next,there are another phenomenon and error massage appear
    How can I handle?
BR
lanxiang
Re: Vivado2013.4 ILA debug error about vcse_server.exe and others
The error shown in the log file appears when the cable is not plugged in or if the board is not powered. Please recheck if the cable is connected properly and board is powered.
Deepika.
Deepika.
Here is the error message you attached:
Vivado Commands
display_hw_ila_data [upload_hw_ila_data hw_ila_1]
[Labtools 27-1348] vcse_server socket connection: Client did not receive response, socket read failed. Error: 10054
[Labtools 27-1319] Connection to vcse_server lost. Check the status of the vcse_server application running on [localhost:60001].
Once the vcse_server application is verified to be running, use disconnect_hw_server and connect_hw_server to re-establish connection.
Two reasons I could think of.
1. VCSE_server got disconnected
2. connection to server is slow to perform the operation
