lanxiang.ben
Vivado2014.1 ILA touch error
Hi All
    When I "Run Trigger Immediate",There are some Error as ancessory
    What the errors mean?and How can I handle the error?
BR
lanxiang
athandr
What is the results if you remove one of the ILA cores?
Also do you need 4 ILA cores in your design unless all these have different CLK?
If they have same CLK, can't you connect the debug signals to the existing probes in existing ILA cores.
Anirudh
athandr
After that check a related AR - http://www.xilinx.com/support/answers/60631.html.
Although not exactly the same, try and check if it works.
However in your case it looks like a problem with the tracememory size.
Anirudh
