WARNING: [Labtools 27-2188] CONTROL.WINDOW_COUNT adjusted
set_property CONTROL.WINDOW_COUNT 32 [get_hw_ilas hw_ila_2]
run_hw_ila [get_hw_ilas -of_objects [get_hw_devices xcvu9p_0] -filter {CELL_NAME=~"flash_top/ila_0"}]
WARNING: [Labtools 27-2188] CONTROL.WINDOW_COUNT adjusted for hw_ila [hw_ila_2] to [1]
INFO: [Labtools 27-1964] The ILA core 'hw_ila_2' trigger was armed at 2018-Nov-24 16:57:10
why is it adjusted?
Re: WARNING: [Labtools 27-2188] CONTROL.WINDOW_COUNT adjusted
The number of captured samples returned from the probe is equal to the DATA_DEPTH property of the ILA core. The default data depth is 1024 samples.
Default properties.
CONTROL.DATA_DEPTH is set to the MAX_DATA_DEPTH of the hw_ila object.
CONTROL.WINDOW_COUNT 1
CONTROL.DATA_DEPTH - Defaults to the MAX_DATA_DEPTH of the ILA debug core, which was set when the debug core was created or inserted into the design. The data depth defines the number of data samples the hw_ila object can capture in a data window.
Set the data depth as an integer which is a power of two, from 1 to the maximum data depth (MAX_DATA_DEPTH) of the hw_ila.
Note: The value of DATA_DEPTH is related to CONTROL.WINDOW_COUNT by the equation
DATA_DEPTH * WINDOW_COUNT = MAX_DATA_DEPTH
Now in you case, warning says it is adjusted to 1. Because default data_depth is 1024 and you are setting window count to 32 which would be 1024*32 = 32768 as per the above equation. This will not satify the equation. That is why it moved the value to 1.
If you want to set window_count to some other value then change the data depth. For example set data_path to 64 & set the window_count to 16.
Snapshot from report_property.
Harshit
Default properties.
Harshit
Hi @m006,
Did Harshit's post explained and help you solve the issue?
If it did help you, please mark is as a solution. If you still see the issue, please reply back and let us know.
Andre Guerrero
Product Applications Engineer
