WARNING: [Labtools 27-3403] Dropping logic core with cellname:'u_ila_0' from probes file, since it cannot be found on the programmed device
I added some debug core to capture the signal and I can see the core 'u_ila_0' was generated in IMPLEMENTATION. But when I click Generate Bitstream.  The core 'u_ila_0'  was dropped and the Tcl Console returned :
WARNING: [Labtools 27-3403] Dropping logic core with cellname:'u_ila_0' from probes file, since it cannot be found on the programmed device.
How can I solve this?
THANKS!
Re: WARNING: [Labtools 27-3403] Dropping logic core with cellname:'u_ila_0' from probes file, since it cannot be found on the programmed device
I finally solved the problem. The reason I got the warning is that the frequency of Jtag is higher than the clock of debug core. So I solved it by changing the frequency of Jtag to lower.
