annu_shah
WARNING:iMPACT:923 - Can not find cable, check cable setup !
hi when i open impact and click on intialise chain i get this error
Welcome to iMPACT
iMPACT Version: 14.7
Project: E:\zed\\auto_project.ipf created.
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Source driver files not found.
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
the Cable Setup operation.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
 Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Cable autodetection failed.
ashishd
Please check this answer record
http://www.xilinx.com/support/answers/30184.html
Ashish
athandr
Try to do a quick unistall re-install of the drivers and check if it works.
 (1)    In a command prompt browse to your C:/Xilinx/<ISE_version>/ISE_DS/ISE/bin/nt64 directory on 64-bit installs. i.e. type cd C:/Xilinx/<ISE_version>/ISE_DS/ISE/bin/nt64
(2)    To uninstall the jungo drivers type the command:  wdreg -compat -inf windrvr6.inf uninstall
 (3)    To reinstall the jungo drivers type the command:  wdreg -compat -inf windrvr6.inf install
Anirudh
ashishd
Did you check responses for your query?
Are you still facing any issue related to cable drivers?
Ashish
kmarvin
Hello, I had the same issue as above, and reinstalling the drivers did not help. Any other advice?
rjensen9752
I get the same warning, WARNING:iMPACT:923 - Can not find cable, check cable setup !, but also, in the Console window, get:
Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170.
Invalid device driver license.
And I get a message, in the notification area of the task bar:
Windows - Fatal Application Exit
WinDriver - Your 30 day evaluation period has expired! Please
contact sales@jungo.com for assistance.
I contacted Jungo and they said to contact Xilinx for this issue.
I'm using ISE/iMpact 14.7 on an XP machine. This has worked in the past, but has stopped working now. I have tried various solutions from AR#30184 and AR#31397 to no avail.
Thanks for any additional help.
amkichu
Did you succeed in finding the solution?
