Observer dreamertom
Waveform Data Read From ILA Core Is Corrupted
I'm using VIVADO 2016.1 and I try to use VIO and ILA in a same design. At the beginning, I can read back data and display waveform from the ILA core. After I adding 4 new probes of signals into the ILA, then I can trigger it but it corrupted when it uploading data and no waveform been displayed. I can get the error message shown in the image below.
pic1
The clock connected to the ILA is a 200Mhz free running clock from a crystal, and the JTAG clock is a 6Mhz clock. I also tried a 3Mhz JTAG clock and it didn't work either. After that, I will try to reduce the number of signals connected to the ILA later. I wonder know the number limits that I can connect to the ILA core by the setup debug tool in VIVADO.
Re: Waveform Data Read From ILA Core Is Corrupted
Hi @dreamertom,
Is timing met for the design?
Arpan
Observer dreamertom
I find that I forget adding the clock timing constraints. I will try again after adding it.
Hi @dreamertom,
Please ensure all timing constraints are met before debugging and you have properly constrained all the paths.
Please check the below Answer record:
https://www.xilinx.com/support/answers/62421.html
Sravanthi B
Thanks & Regards,
Sravanthi B
Hi @dreamertom,
Are you able to debug after taking care of timing constraints?
Arpan
