mathmaxsean
When use chiscope in vivado, shows:" there is no debug cores?"
HI,
 I am trying to add chip-scope in to my vivado project.
I select the debug IP core , add to my top design and generate the bitstream.
After download the bitstream the vivado says "there is no debug cores" . And cannot find the debug core.
I am using Zynq device but in my vivado project there are just the pure logic no PS part.
SO I wonder do I need to add PS part into my vivado project to use the chipscope?
Any hint is appreciated!
a_chami
Is the clock coming from the Zynq?
If that is the case you have to run an SDK so the Zynq will boot and activate its clocks
Avi Chami MSc
FPGA Site
mathmaxsean
@a_chami
Thanks for remind.
I check the .xdc file pin number.
I used the following pin as the system clock input, which is a independent clock from the zynq.
a_chami
Maybe you should try by using the 'P' pin (N13)
Avi Chami MSc
FPGA Site
