hardwareheini
Where and how to buy the ChipScope?
I am using the ISE WebPack targeting an Spartan-6. I want to buy the ChipScope License but TBH I don't know how to do this.
The XILINX Online Store, as described in this posting, returns a 404. DigiKey lists the ChipScope, but marked it as "Obsolete" and I can not buy it. Where can I get the license and is there something I am missing?
kind regards,
Christian
nupurs
@hardwareheini,
Please regenerate the license using steps given in this AR so that the Chipscope_pro feature gets added to your license:
https://www.xilinx.com/support/answers/36136.html
Nupur
arpansur
Hi @hardwareheini,
If your device is supported in webpack then you can use chipscope for free.
It's included in webpack license.
Please go through https://www.xilinx.com/products/design-tools/ise-design-suite/ise-webpack.html
Arpan
nupurs
@hardwareheini,
No purchased license is needed.
Nupur
balkris
check this ARs
https://www.xilinx.com/support/answers/36493.html
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v2012_4---14_7.html
Thanks and Regards
Balkrishan
hardwareheini
@nupurs and @arpansur Thanks for the quick answer, this would be very nice if I don't have to buy the CS.
However I get the message in the attachement when I insert an CS Core into my design in ISE. My License seems to be expired. Is there a way to reset this?
kind regards,
Christian
nupurs
@hardwareheini,
Please post your license file here.
Which device are you using?
Nupur
hardwareheini
@nupurs I am targeting an XC6SLX16-2FTG256
kind regards,
Christian
nupurs
@hardwareheini,
Nupur
arpansur
Hi @hardwareheini,
This device is supported in webpack. But the chipscope features are missing in the license. May be you generated the license before these features are added in webpack. So please try @nupurs suggestions to regenerate the license to include these features.
Arpan
hardwareheini
@nupurs, @arpansur, @balkris Thanks very much for your help, guys! I deleted the License from my Online License Manager, created the new one and now ChipScope is running perfectly.
kind regards,
Christian
btrac
I am going through the same scenario, it isn't obvious which licence I need to get.
Do I need to delete my old licence from the "Manage Licences" tab? I have aquired 8 over the years and have deleted 3, I am unable to delete any more:
"Sorry, you have exceeded the maximum number of allowed license key regeneration operations. Please submit a Service Request from the Xilinx Web Portal for further assistance."
arpansur
Hi @btrac,
Please create a new thread in Installation and licensing board with your query.
Arpan
nupurs
@btrac.
Raise a non-technical service request here: https://www.xilinx.com/support.html#serviceportal
Nupur
btrac
I've requested service portal access so now it's just a waiting game. I'll see how this pans out, cheers :)
btrac
Request denied! Seems I didn't register with a corporate email address. Xilinx, please fix the license delete function, Google suggests this has been a problem for years!
Meanwhile, I will have to create a new account :(
