willwu
Why insert command generated different CDC file?
1, insert & open GUI ;
connect the signals and save CDC;
2, insert -create ss.cdc; insert -edit ss.cdc -ngcbuild -i ss.edf ss.ngc; connect the signals and save CDC;
the devicefamily of the two .cdc is different.
The first one is "Project.device.deviceFamily=17"
The second one is "Project.device.deviceFamily=-1"
when using insert -insert for the second .cdc, tool error generated as following:
<CoreGen>:ERROR:sim - Invalid command: set devicefamily =
See CoreGen Log /..../cs_icon_pro/coregen.log
ERROR:Unable to generate icon_pro.ngc
ERROR:Double-click the mycounter.cdc icon in the source window to edit an fix the CDC project
When using insert -insert for the first .cdc, the core inserted successfully.
The device is Virtex6.
willwu
who can answer it?
liquid7068
I got the same issue with you, how did you fix it?
