legoman
XDC port direction?
I defined my top level I/O ports with Vivado I/O planning project and got following output:
set_property DIRECTION OUT [get_ports spi_en]
set_property IOSTANDARD LVCMOS18 [get_ports spi_en]
set_property DRIVE 12 [get_ports spi_en]
set_property SLEW SLOW [get_ports spi_en]
After this I created simple Vivado block design with MicroBlaze and AXI-Quad SPI interface, and instantiated it inside my top level HDL-wrapper.
Now after implemetation I'm getting following errors on Vivado:
"Command failed: Cannot change direction of connected port 'spi_en'"
"Command failed: Cannot change direction of connected port 'spi_clk'"
"Command failed: Cannot change direction of connected port 'spi_din'"
"Command failed: Cannot change direction of connected port 'spi_dot'"
If I remove the "set_property DIRECTION OUT [get_ports spi_en]" from the xdc-file I get rid of the errors and the pins are showing correctly in the schema with INBUF and OBUF instances. So is the block design taking already care of the port directions and I don't actually have to define those in the xdc-file at all?
balkris
check this ARs
https://www.xilinx.com/support/answers/63174.html
https://www.xilinx.com/support/documentation/application_notes/xapp586-spi-flash.pdf
Thanks and Regards
Balkrishan
vemulad
Hi @legoman
Yes, your understanding is correct.
set_property DIRECTION constraints are typically used in IO Planning projects. In full projects, where the IO directions have been defined in top level RTL, the constraints are no longer necessary.
Simply remove the constraints to resolve the errors.
Deepika.
