XPE2015.3 and XPE2016.1 don't work with excel2013
Hi experts,
1) I can't push the buttons in top, e.g. "Import File",  "Export File", "Quick Estimate"....
2) I was able to choose Artix Family, while the devices available are still Kintex7.
Fortunately, I found my 2014.3 could work well.
I tried AR# 63366 and AR# 63237, but it seems they are only for excel2010.
Chris
Re: XPE2015.3 and XPE2016.1 don't work with excel2013
I could find the XPA works fine with excel 2013. can you check if the attached files do not work at your end?
I still can't use those buttons. Can I estimate FPGA power consumption with XPE2014.3?
Chris
You can estimate FPGA power consumption with XPE2014.3. Please try with a different machine to check if your observations are related to the MS office installation in that specific machine.
Thank you very much.
Chris
Just to check can you follow these steps,
  1. Close all Excel documents
  2. Open a blank document
  3. Excel options > Trust center settings>macro settings>Select{Disable all macros with notifications}
  4. Active X settings >
Select either:
  • Disable all controls without notifications
  • Prompt me before enabling all controls with minimal restrictions
Apply all settings and close.
Open the Our excel file
Now again allow the prompt to enable macros
And check if you can see any change.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Are you still facing any issue? If not, please mark Accept as Solution for an answer.
-Shreyas
