XPS Microblaze Interrupt Setting MISSING?
In XPS 14.7, I'm trying to recreate from scratch a reference design originated in XPS 12.4.  I've got almost everything worked out, except for an issue with the microblaze interrupt.  Please see the two images below.  Do I need to resolve this?  And if so, how do I do it, please?  (I've edited the images for brevity, then highlighted in yellow my points of question)
From the original XPS 12.4 design:
From my recreated XPS 14.7 design:
In XPS 14.7, you will find the INTERRUPT in the bus interfaces tab:
Doh!  They MOVED it!  Thanks.  But NOW WHAT?
It says "No Connection" and doesn't provide any alternative in the dropdown box.
Meanwhile, I went to the xps_intc_0, which still has interrupt on the Ports tab.  The only internal choice it would allow me is "xps_intc_0::Intr".  So I chose that.  But back on the Bus Interfaces tab for microblaze_0, it will won't let me select anything other than "No Connection".
Thanks for the changed tab advice, and thanks in advance if you can get me past the above.
