Visitor lkosmann
XPower Duty Cycle out of Range
Hi I'm currently analysing xpower results of different components, and struggling with Error 1653:
ERROR:Power:1653 - Duty cycle <200.00> must be in range [0..100]%
 In order to investigate what causes this Error, i found some forum threads, that have different solution, but won't help to understande how this duty cycle is calculated and why it may become larger than the designated range.
I have different values for the error (this is just part of the hole error log):
ERROR:Power:1653 - Duty cycle <200.00> must be in range [0..100]% for xin2<1>.
ERROR:Power:1653 - Duty cycle <136.00> must be in range [0..100]% for delay_bph_d0<7>.
ERROR:Power:1653 - Duty cycle <179.00> must be in range [0..100]% for delay_dltx_address1<2>.
ERROR:Power:1653 - Duty cycle <186.00> must be in range [0..100]% for delay_dltx_address1<0>.
ERROR:Power:1653 - Duty cycle <105.00> must be in range [0..100]% for delay_bpl_d0<7>.
Now i determined other information i can get within the power report e.g. the toggling rate and the % High (second nummer 100, 91, 92...)
				name					Rate    % High	Duty Cycle from error
3.3.2IO			xin2<1>					1.39	100		200
3.3.1.2. Signals	delay_bph_d0<7>			5.56	91		136
3.3.1.2. Signals	delay_dltx_address1<2>	8.33	92		179
3.3.1.2. Signals	delay_dltx_address1<0>	2.78	97		186
3.3.1.2. Signals	delay_bpl_d0<7>			2.78	99		105
So do these values have any connection to each other, or can I ignore the error? It would be very nice to have an idea of what the error really means and how this duty cycle is calculated.
Re: XPower Duty Cycle out of Range
check this thread: http://forums.xilinx.com/t5/Design-Tools-Others/Error-on-Xpower/td-p/313501
Vinay
Visitor lkosmann
I was aware of this post, but it doesn't help,
"For the LSB of a counter, on 100 MHz clock, that is 1/2 100 (50% duty cycle), or 50 MHz....etc."
That is true and understandable, the duty cycle in this example is 50. But for a toggle rate of 1.39 which formula do i have to use to get to a duty cycle of 200. I thought duty is somehow equivalent to % of time high.
Also according to the post, large parts of my designs have to be implemented in DDR with strange rates (strange values for 2)
Try generating SAIF file using Isim and using it in Xpower Analyzer instead of VCD file. You may not get this error any more.
