Observer emil_kruki
Xilinx IVT for ISE13.4
I have some problems by using of IVT on ISE13.4. After I set the XILINX enviroment variable, I still can not run successifuly the IVT tool. Here is the output of IVT in my console:
$ ivt -verbose -f SCC_LAB_TOP_ucf.ivt
Xilinx Isolation Verification Tool 7.41
Copyright (C) 2006-2013 Xilinx, Inc.  All rights reserved.
  'ivt -h' displays a brief argument summary.
  'ivt -license' displays the license agreement.
Segmentation fault
Do you have any idea or suggestions?
Best regards,
Emil Gracic
Observer emil_kruki
Re: Xilinx IVT for ISE13.4
I found a solution for this issue: Use the ISE Design Suite Command Prompt instead of windows console.
Best Regards,
Emil Gracic
Which OS are you running in?
Check the following AR for supported list
http://www.xilinx.com/support/answers/18419.html
Thanks,Vijay
Observer emil_kruki
Hi Vijay,
thanks for reply. I'm running in Windows 7 Pro 64-bit. I have downloaded the 64-Bit version of ivt and installed it into ISE\bin\nt64 directory.
Best regards,
Emil Gracic
Observer emil_kruki
Best Regards,
Emil Gracic
