william.werner
Xilinx SEU Estimator
I downloaded the Xilinx SEU Estimator (Excel) in order to generate an estimate for XCZU15EG-2FFVB1156I (Zynq UltraScale+ MPSoC). In the "Overview" they list this type, but in the tool under "Family" I don't see this one listed in the pull-down. I also looked through each one listed in "Family" and still did not see this part type listed. Is the Zynq UltraScale+ MPSoC covered in this tool? If so please let me know how I can select that type.
thank you
Bill Werner
william.werner
Thank you for your quick response, I have used the link and accepted the terms and conditions.....received a response from that page that I will hear back on the approval to use the tool within 2 days.
thank you
Bill
hj
I can see them under Zynq Ultrascale+ devices. Here is the snapshot.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
william.werner
You have a newer version than the one I downloaded this afternoon from the Xilinx Website....the one I just downloaded is 2016.1 and I see you are using 2017.3.  Can you provide a link to the version you are using?
thanks much
Bill
hj
Hi Bill,
Here is the link https://www.xilinx.com/member/seu/xilinx-single-event-upset-estimator-license-agreement.html
william.werner
thank you
Bill
