arasch
ZC706 "Program Device" grayed out
I have a ZC706 Evaluation Board and am running Vivado 2018.2. I would like to program the Zynq using just USB cable. Unfortunately the computer I am using has only 2 USB hubs, so I am using a 4-Port USB 2.0 Hub to be able to connect the 2 cables from the ZC706 board besides the connections required for keyboard and mouse.
I have the SW4 set to 01 and SW11 to 00000.
When I try to Auto connect in Vivado to the hardware "Program Device" stays grayed out. Also trying to Program FPGA from the Xilinx SDK results in an error message that the communication to the hardware is not working.
Thanks for any hint on what I am doing wrong.
hj
• CentOS 7.2, 7.3, and 7.4 (64-bit)
• CentOS 6.7, 6.8, and 6.9 (64-bit)
These are supported with Vivado 2018.2. If you are using any of those then it should work.
Next re-install the cable drivers. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug973-vivado-release-notes-install-license.pdf
Page#30
harshit
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
hj
@arasch
Can you share the snapshot from Vivado HW manager? Make sure no other HW server session is open.
Also try to reconnect the board. Use the red circled switch as well.
Try to use the TCL command if any useful error message is triggered:
set_property PROGRAM.FILE {C:/impl_1/Golden.bit} [get_hw_devices xc7z045_1]
program_hw_devices [get_hw_devices xc7z045_1]
Harshit
arasch
Hi @hj
Thanks for the quick reply.
Please see the screenshot attached. I don't seem to get further than the localhost. Also tried the refresh_hw_server option.
I should also add that I am using CentOS Linux.
Best Regards
hj
Try to check task manager is there any hardware session(hw_server.exe) /SDK open. End the process for all of them and try to re-connect the board.
Use only one session at a time. I can see SDK open in your snapshot.
Restart vivado or close the local server and re-connect the HW.
ZC706 mode pins for JTAG should be SW4 --> 01
harshit
arasch
Hi @hj
Thanks for the reply.
I am running Vivado on CentOS-7 Linux and (after running "source /opt/Xilinx/Vivado/2018.2/settings64.sh") I am starting it just with
> vivado &
Is there anything else I have to do on Linux?
Could the USB hub be an issue?
Best
hj
Page#30
harshit
arasch
Thanks so much -- of course forgot to install the driver on Linux...
Now it works.
