mglorieux
Zynq U+ ILA vector range check
I try to implement a Vivado Integrated Logic Analyzer (ILA) in the FPGA section of a ZU3EG-ES1 device.
I generated the core using the GUI, instantiated it, and ran the synthesis and implementation flow without issue (as I have already done on Kintex7).
My issue is related to the usage of the ILA in the hardware manager. I power-up the device, I configure the FPGA and release the reset of the processor (clock is derived from the processing system) from the SDK. Clock propagates correctly to the FPGA as my PLLs locks (observed on LEDs). However, when I refresh the device in vivado hardware manager, using the correct debug probe files, I have the following message in the console :
refresh_hw_device [lindex [get_hw_devices xczu3_0] 0]
INFO: [Labtools 27-2302] Device xczu3 (JTAG device index = 0) is programmed with a design that has 1 ILA core(s).
vector::_M_range_check: __n (which is 5) >= this->size() (which is 5)
The core is then not usable as vivado cannot map the signals.
Is my procedure to configure the device is correct? What is the meaning of this message and how to solve this issue?
mglorieux
I found the solution: The ILA clock frequency in the hierarchy of my design was to slow (it must be twice the JTAG frequency, as pointed out here : https://forums.xilinx.com/t5/Design-Tools-Others/need-a-slow-clock-for-ILA/m-p/775890#M10561)
Thanks for your help!
arpansur
Hi @mglorieux,
Which version of the tool you are using?
Arpan
mglorieux
Hi Arpansur,
Thanks for your reply.
I am using 2017.1
arpansur
Hi @mglorieux,
Can you try with System ILA?
Arpan
mglorieux
Hi Arpan,
Thanks for your suggestion.
I made several trials:
- Implementing the system ILA in the same block design as the ZYNQ processor (hierarchical level 1) => works
- Implementing the system ILA in a different block design, and instantiate it in my FPGA design hierarchy (level 2), as I did with the ILA => does not work: Same message about vector range
- Try with 2017.2 tools, with the ILA (not system ILA) => does not work, with the same error message.
Thanks for your support
mglorieux
