Anonymous
Not applicable
a chipscope problem
hello,I have a question with using chipscope.
 I open the cable and search JTAG chain , download the bit file successfully.The problem is that the ILA can not be opened at all.Nothing appears and i can not find the signals to analyze.I remember that the ILA should be started automatically.I do not know the reason.
Re: a chipscope problem
Hi @Anonymous,
Please go through following document to verify if something is missing
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/ug750.pdf
Arpan
Arpan
Hi @Anonymous,
Arpan
Arpan
Anonymous
Not applicable
Thank you very much for your reply.
The problem occurs today.The ILA is functioning well yesterday and I have been using this ISE version on this PC for several months,so I think the software is installed successfully and.What is more, i do not remember any change about the settings.Quite confused
Hi @Anonymous,
Is it the same design that was working previously?
If so are you getting any warning message?
Arpan
Arpan
