Anonymous
Not applicable
.bif file to create Zynq boot image in SDK - with relative paths rather than absolute paths
In the Vivado SDK, the 'Create Zynq Boot Image' menu uses a .bif file to create a .bin file. The .bif file has absolute paths, something like this...
the_ROM_image:
	[bootloader]D:\MyDir\project.sdk\fsbl\Debug\fsbl.elf
	D:\MyDir\project.sdk\hw_platform_0\top.bit
	D:\MyDir\project.sdk\MyApp\Debug\MyApp.elf
Is there a way to specify relative paths - relative to the project?
In TCL scripts, we use something like this to get relative paths...
# Get the project's directory and .bit file
set prjDir [get_property DIRECTORY [current_project]]
set bitFile $prjDir/[current_project].runs/impl_1/TOP.bit
I'd like to find a similar way to utilize relative paths in .bif files.
Edit:
found similar question here: http://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-BootGen-Current-Directory/td-p/238446
Community Manager
Community Manager
Re: .bif file to create Zynq boot image in SDK - with relative paths rather than absolute paths
You can do this by setting "Path Variables" in SDK.
Please go to SDK help for guidance on setting this up.
Anonymous
Not applicable
Do you mean I'd reference a path variable in the .bif file? Something like...
[bootloader] ${PROJECT_LOC}\project.sdk\fsbl\Debug\fsbl.elf
Anonymous
Not applicable
I tried referencing a path variable in the .bif file but it looks like .bif files don't de-reference path variables. Using the example above, WORKSPACE_LOC is defined as D:\MyDir\project.sdk. The .bif file can find D:\MyDir\project.sdk\fsbl\Debug\fsbl.elf but not ${WORKSPACE_LOC}\fsbl\Debug\fsbl.elf.
How would path variables help with .bif files?
I have the same question as the original poster. Would you please answer his question at the end of this thread?
I have the same question.  Does anyone have an answer yet?
If you used a [glob -directory <path> uboot.elf] here would this resolve the path?
I am also trying to use relative paths in a bif file, 2016.3
I registered a post_build.bat in "C/C++ Build" -> Stettings -> "Build Steps (Tab)"
to recreate the bif file on every build.
post_build.bat
echo //arch = zynq; split = false; format = BIN > ..\bootimage\app.bif
echo the_ROM_image: >> ..\bootimage\app.bif
echo { >> ..\bootimage\app.bif
echo     [bootloader]%cd%\..\..\fsbl\Debug\fsbl.elf >> ..\bootimage\app.bif
echo     %cd%\..\..\system_hw_platform_0\sw_model_top_wrapper.bit >> ..\bootimage\app.bif
echo     %cd%\app.elf >> ..\bootimage\app.bif
echo } >> ..\bootimage\app.bif
This results in a bif looking like
app.bif
the_ROM_image:
    [bootloader]C:\PathToWorkspace\app\Debug\..\..\fsbl\Debug\fsbl.elf
    C:\PathToWorkspace\app\Debug\..\..\system_hw_platform_0\sw_model_top_wrapper.bit
    C:\PathToWorkspace\app\Debug\app.elf
It seems that relative "redirectors" (..\..) within an absolute path are allowed.
