chipscope. Triggers and Dataports doesn't display the signal name.
I have come across this problem that the trigger port does not display the signal name. For example, it is supposed to be "Start", yet the chipscope just shows the "Trigger Port0[135]"... how did this happen?
A different  problem happened to the data ports. for example the signal datair is a 15 bit width signal, and it's supposed to display itself as ONE 15-bit signal, not as the 15 separate 1-bit signal in the 2nd picture....
please help...thanks in advance.
Re: chipscope. Triggers and Dataports doesn't display the signal name.
Can you write the steps that you used to instert chipscope core and if made any modifications? However if possible, attach the screenshots when you were making connections to the ports.
Vishal
