sraza
chipscope, no core found...
hello,
I am trying to use chipscope bu t do not get succes in getting signal on the chipscope pro analyzer...
I cannot understand why. The below INFO message appears. It also appears when I am running the xilinx official user guide UG750...
I am using virtex-6 ML605 board. Accoring the messageit found no core, but I have done what the tutoral in the user guide says. Looking forward for reply. (please see the message below)
INFO: Found 0 Core Units in the JTAG device Chain.
bests,
Jaffry
vemulad
Did you check this article http://www.xilinx.com/support/answers/19337.htm?
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
