sraza
design or timing problem with inclusion of chipscope core
hello all,
Chipscope core is introduced in my design only for debug purpose.
later I wish to take it out... But my question is that if I include chipscope core, there will be definitely timing differences, I suspect including chip scope I intend to include more than 500 signals (collectively) to the chipscope core.
The reason is that the design is quite large, involving DDR3 communication block + algorithm implementation + address generation.... Hence I am worried about the performance with and without chipscope...i.e. if I debug my design (which I find very useful actually...) using chipscope but later if removed and it work differenly bcz of timing changes....
thank you in advance
rcingham
Yes, the design will work differently without ChipScope.
Usually, the design will have better timing without ChipScope, but if (like 1 design I had) it fails STA when ChipScope is taken out, you just have to put it back in.
rcingham
debrajr
Is your issue resolved already? If Yes, please post your solution for the benefits of others and if No, kindly let us know so that we can help. if the posts for your topic have helped you, do remember to select them as "Accepted Solutions" to close the topic.
Debraj
sraza
thank you for reminding. I will keep in mind this thing
