Tetra57
disable the suggestion on vivado
Hello.
I've recently started to use Vivado and felt inconvenience about the text editor.
How can I disable the suggestion?
barriet
Try:
menu: Tools -> Settings, Text Editor, Code Completion -> Disable Code Completion.
There's quite a few other settings you can check out. Or certainly welcome to use a different text editor.
joancab
Advisor
Advisor
what inconvenience? which suggestion?
dpaul24
@Tetra57
Which suggestion?
If u want to use the text editor of your choice: Tools -- Settings -- TextEditor -- Change to the text editor of your choice!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Tetra57
@dpaul24 @joancab
I thought I attached a picture, but it didn't work. Sorry about that.
As you can see in the image, it is the function that are analogous to the characters I type.
barriet
Try:
joancab
Advisor
Advisor
Oh, man, that I also wanted to disable, it's simply anti-helpful (meaning worse than not helpful, or negative helpfulness, mathematically speaking)
Tetra57
@barriet Thank you, it works.
@joancab Definitely. I disabled it and it got so much clear and nicer.
