Visitor simonrix
encryption key wrapping
Hello Everyone,
I am trying to find out some information on the key wrapping algorithm used in the bitstream key rolling as I cannot seem to find this anywhere. I am assuming a AES based KEK such as NIST Special Publication 800-38F - December 2012 but would appreciate being able to confirm this. I am not sure which is the best forum to ask this on and would appreciate a pointer as I have other questions about how I can secure a design in cloud solutions such as Alveo.
Regards Simon
Re: encryption key wrapping
Hi @simonrix,
The encryption process is based on AES-256 GCM bitstream encryption.
You can find an overview of the encryption process in the video UltraScale+ Security Lock Before you Leave  and in more details on the document UltraScale Architecture Configuration - UG570, Chapter 8.
In a similar manner, when creating an application for the Alveo boards, you can encryption the RTL kernels before its packaged for use with SDx.
Andre Guerrero
Product Applications Engineer
Hi @simonrix,
Andre Guerrero
Visitor simonrix
Thank you, I will read and revert with further questions thereafter if any.
Visitor simonrix
Hello Andre,
Thank you, I have read the suggested documentation and have a further question I would rather not ask on an open forum. I would be grateful if you can let me have an email address to send it to directly please?
regards Simon
Hi @simonrix,
If you already have already acquired a Xilinx device, you may have dedicated Field or Sales Engineer from Xilinx (or from Avnet). If that's the case,would you please contact and request them to open an SR with Xilinx? that way, your questions will be forwarded straight to a Xilinx employee who is an expert in Encryption.
if you do not have a contact yet, please send me a private message her on the Forums and I'll try to help you.
Thanks!
Andre Guerrero
