how to monitor signal in high-impedance state with ila?
hi,
I want to monitor a signal which sometimes in high-impedance state .Does the ila can monitor it?What should I do?
Re: how to monitor signal in high-impedance state with ila?
Hi @chenyang1994,
Usually high-impedance signal will be accompanied with pull-up or pull-down. For the value of a signal internal FPGA, it can only be detected as '0' or '1'. High-impedance status can't be shown by ila.
Martin
Hi @chenyang1994,
Martin
Scholar markcurry
If the signal is an output signal generated by the FPGA, then monitor the tri-state enable pin.
Mark
