Participant georgedu
how to verify the FPGA loading file manually
I use the iMPACT to verify the FPGA downloading file and the tool shows it  succeed
I notice iMPACT generate the iMPACT.rbd file .Then I compare this file with the original .rbd file (generated when bitgen )
Unfortunately ,this two file is quite different ,(I difff them in vim ), Can anybody tell me the reason ?
Thanks in advance .
Re: how to verify the FPGA loading file manually
in the generated file by bitgen command ,the rbd file is :
Xilinx ASCII Bitstream
Created by Bitstream P.28xd
Design name: tri_1.ncd;UserID=0xFFFFFFFF
Architecture: spartan6
Part: 6slx45tfgg484
Type: readback
Date: Sat Aug 31 07:13:42 2013
Bits: 11872912
0000000000000000
0000000000000000
0000000000000000
and in the generated file by iMPACT:
1111111111111111
^@1111111111111111
^@1111111111111111
I open these two in the vim
Community Manager
Community Manager
refer to this answer record- http://www.xilinx.com/support/answers/53024.htm for explanation.
