iMPACT: 923 Can not find cable, check cable setup !
I have successfully deployed the program to FPGA using my laptop. But when I use my desktop (Linux), the boundary scan in iMPACT doesn't work. Please give me some solutions!!
The console is like below:
GUI --- Auto connect to cable...
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
File version of /home/xq32/software/ISE14/14.4/ISE_DS/ISE/bin/lin64/xusbdfwu.hex = 1030.
 Using libusb.
Please run `source ./setup_pcusb` from the /home/xq32/software/ISE14/14.4/ISE_DS/ISE//bin/lin64 directory with root privilege to update the firmware. Disconnect and then reconnect the cable from the USB port to complete the driver update.
Cable connection failed.
Connecting to cable (Parallel Port - parport0).
 Linux release = 2.6.32-431.20.3.el6.x86_64.
WARNING:iMPACT -  Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
WARNING:iMPACT -  Module parport_pc is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
Connecting to cable (Parallel Port - parport1).
Connecting to cable (Parallel Port - parport2).
Connecting to cable (Parallel Port - parport3).
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Re: iMPACT: 923 Can not find cable, check cable setup !
Install cable drivers.
Check this user guide: http://www.xilinx.com/support/documentation/user_guides/ug344.pdf
Vinay
