vmnrao
iMPACT Access Permission Problem
Hi All,
I'm using iMPACT 9.1i (as part of ISE/EDK 9.1i- latest version that fully supports the Xilinx ML310 board I'm using) on Linux. I am encountering what seems to be a minor problem, which is that iMPACT seems to be automatically starting with a project directory set in the root directory. Because it does not have permission, I get the following dialog: "The Project Directory / is either not writable or does not exist. iMPACT has chaged the ProjectDirectory to the corrent working directory /home/v". When I dismiss this dialog, iMPACT quits.
Any idea how to change the initial startup directory preference, or otherwise fix this problem?
vmnrao
bump
debrajr
Have you been able to fix this issue yet? If yes, kindly post the resolution here for others to check. If not, let us know.
Debraj
