07-16-2013 12:47 PM
Hi All,
I'm using iMPACT 9.1i (as part of ISE/EDK 9.1i- latest version that fully supports the Xilinx ML310 board I'm using) on Linux. I am encountering what seems to be a minor problem, which is that iMPACT seems to be automatically starting with a project directory set in the root directory. Because it does not have permission, I get the following dialog: "The Project Directory / is either not writable or does not exist. iMPACT has chaged the ProjectDirectory to the corrent working directory /home/v". When I dismiss this dialog, iMPACT quits.
Any idea how to change the initial startup directory preference, or otherwise fix this problem?
07-18-2013 10:22 PM
bump
07-28-2013 12:02 AM
