iMPACT Error :2258
I have a serious problems with iMPACT
I work with ISE 11.5 on WinXP.
The target FPGA is  xc6lsx100-2gg484.
the PROM is xc32p
During the create PROM file i received the following error message
"iMPACT:2258 - Failed to set clock to JtagClk"
What does this mean and how can I fix it?
 Here is the exact input sequence:
-> create Prom file -> Xilinx Flash Prom  =>
    add storage devices  -> xcf32p =>
       enable revisioning  -> NO
       output file name : top_progr    -> ok
          start adding device file to revision 0
    choose : topprg.bit => open
           .... ERROR Message  : "iMPACT:2258 - Failed to set clock to JtagClk"
Then I deleted the project directory and create a new design project with exactly the same name, VHDLsource files,  coregen dir etc.
According to a new synthesis, implementation, P & R and generate programming file( .bit) I start second time iMPACT to generate the PROM file.
 And then I could generate the PROM file without any error message
This has already happened several times
I think this is certainly not a good solution to delete allways a work directory.
What is the cause for this behavior ?
In the documentation I have no Note found for the ERROR 2258
Thank you in advance
Anton
Re: iMPACT Error :2258
Anton,
Our Impact experts would get back to your post shortly.
Debraj
Debraj
Anton,
Debraj
Debraj
Hi Debraj
for more than a month I am waiting for a response from Impact Expert.
Anton
