iMPACT Error :2258
I have a serious problems with iMPACT
I work with ISE 11.5 on WinXP.
The target FPGA is  xc6lsx100-2gg484.
the PROM is xc32p
During the create PROM file i received the following error message
"iMPACT:2258 - Failed to set clock to JtagClk"
What does this mean and how can I fix it?
 Here is the exact input sequence:
-> create Prom file -> Xilinx Flash Prom  =>
    add storage devices  -> xcf32p =>
       enable revisioning  -> NO
       output file name : top_progr    -> ok
          start adding device file to revision 0
    choose : topprg.bit => open
           .... ERROR Message  : "iMPACT:2258 - Failed to set clock to JtagClk"
Then I deleted the project directory and create a new design project with exactly the same name, VHDLsource files,  coregen dir etc.
According to a new synthesis, implementation, P & R and generate programming file( .bit) I start second time iMPACT to generate the PROM file.
 And then I could generate the PROM file without any error message
This has already happened several times
I think this is certainly not a good solution to delete allways a work directory.
What is the cause for this behavior ?
In the documentation I have no Note found for the ERROR 2258
Thank you in advance
Anton
Anton,
Our Impact experts would get back to your post shortly.
Debraj
Debraj
Anton,
Debraj
Debraj
Hi Debraj
for more than a month I am waiting for a response from Impact Expert.
Anton
