iMPACT - Module windrvr6 is not loaded. Please reinstall the cable drivers
Welcome to iMPACT
iMPACT Version: 14.7
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
If you are using the Platform Cable USB, please refer to the USB Cable Installation Guide (UG344) to install the libusb package.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Linux release = 4.13.0-32-generic.
WARNING:iMPACT -  Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
Cable connection failed.
Connecting to cable (Parallel Port - parport0).
Connecting to cable (Parallel Port - parport1).
Connecting to cable (Parallel Port - parport2).
Connecting to cable (Parallel Port - parport3).
PROGRESS_END - End Operation.
Elapsed time =     59 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
I am facing the above error when using ISE IMPACT with ML605.
I have tried solution such as https://www.xilinx.com/support/documentation/user_guides/ug344.pdf#page=17 but it resulted in https://www.questarter.com/q/install-xilinx-platform-usb-in-ubuntu-16-04-x64-3_838260.html which is not suitable in newer linux kernel version.
I have also tried https://askubuntu.com/a/927901 but the ./install_drivers script within vivado SDK does not help solve this error either.
Besides, compiling http://dreamrunner.org/blog/2012/09/12/install-xilinx-ise-on-the-ubuntu/ gave me some errors. I suppose this solution does not support ISE 14.7 yet.
Could anyone advise ?
Tags (2)
Hi @user123random,
What distro and version of Linux are you using? ISE is a significantly old software and unfortunately it might be difficult to get drivers to work on a new OS's.
Also, what kind of cable are you using (Digilent or Xilinx USB cable)?
You might have to install the drivers from the Vivado installation. Please take a look at the following AR, which points a workaround to install the drivers for each cable on newer OS's: https://www.xilinx.com/support/answers/64361.html
Andre Guerrero
Product Applications Engineer
Hi @anunesgu
I am using Linux UbuntuHW15 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I am still stucked at cable driver installation error even after trying your previous solution.  By the way, I could get UART on ML605 working now.  Is it possible to download bitstream to ML605 using UART ?
**     Xilinx Virtex-6 FPGA ML605 Evaluation Kit      **
Choose Feature to Test:
1: UART Test
2: LED Test
3: Timer Test
4: FLASH Test
5: IIC Test
6: Ethernet Loopback Test
7: Switch Test
8: External Memory Test
9: System Monitor Test
A: PushButton Test
B: LCD Test
C: System ACE CF Test
D: DVI/VGA Test
1
Reading SRECORDS from Linear BPI Flash at: 0x7C920000
Bootloader: Processed (0x)0000012c S-records
Executing program starting at address: 00000000
**     ML605 - UART Test                              **
Testing UART
9600,8,N,1
Hello world!
UART Test Passed
1: UART Test
2: LED Test
3: Timer Test
4: FLASH Test
5: IIC Test
7: Switch Test
A: PushButton Test
B: LCD Test
D: DVI/VGA Test
Even when I try in Windows 10, I have the same problem as illustrated below. Could anyone advise ?
Hi @user123random,
Unfortunately you cannot use the UART to program the board. Also, unfortunately Windows 10 is not an officialy supported OS for ISE.
Are you looking only to program the board? Or are you using the ISE to do the design as well?
If the issue is programming it, I recommend you install the Vivado Lab Edition, which is free and will come with the latest cable drivers.
In fact, after you install that, it might actually get the drivers for ISE to work as well. Could you please try that?
You can get the Vivado Lab Edition from the following link:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2017-4.html
Please let us know how that goes.
Andre Guerrero
Also get the
when I start iMPACT from
/opt/Xilinx/14.2/ISE_DS/ISE/bin/lin64$ sudo ./impact
I was install both Vivado and ISE14.2 on Linux Ubuntu 16.04. I was install cable driver
/opt/Xilinx/Vivado_Lab/2018.1/data/xicom/cable_drivers/lin64/install_script/install_drivers/
$ sudo bash install_drivers
and get answer after install..
INFO: Driver installation successful.
CRITICAL WARNING: Cable(s) on the system must be unplugged then plugged back in order for the driver scripts to update the cables.
Should I try start iMPACT from Vivado Lab tool instead? I will try..
The LED on Platform Cable USB II is Green and attached to a proper Spartan6 target
Best regards
Olle Welin
Got this Error also when I start iMPACT on Ubuntu 16.04
I was install cable driver like this
/opt/Xilinx/Vivado_Lab/2018.1/data/xicom/cable_drivers/lin64/install_script/install_drivers$ sudo bash install_drivers
INFO: Installing cable drivers.
INFO: Script name = install_drivers
INFO: HostName = dator12345-Lenovo-Y50-70
INFO: Current working dir = /opt/Xilinx/Vivado_Lab/2018.1/data/xicom/cable_drivers/lin64/install_script/install_drivers
INFO: Kernel version = 4.13.0-39-generic.
INFO: Arch = x86_64.
USB udev file exists and will not be updated.
--File /etc/udev/rules.d/52-xilinx-ftdi-usb.rules exists.
--File /etc/udev/rules.d/52-xilinx-ftdi-usb.rules version =
--File 52-xilinx-ftdi-usb.rules exists.
--File 52-xilinx-ftdi-usb.rules version =
--File 52-xilinx-ftdi-usb.rules is newer than the destination file.
--Updating rules file.
--File /etc/udev/rules.d/52-xilinx-pcusb.rules exists.
--File /etc/udev/rules.d/52-xilinx-pcusb.rules version = 0002
--File 52-xilinx-pcusb.rules exists.
--File 52-xilinx-pcusb.rules version = 0002
--File 52-xilinx-pcusb.rules is already updated.
INFO: Digilent Return code = 0
INFO: Xilinx Return code = 0
INFO: Xilinx FTDI Return code = 0
INFO: Return code = 0
One time I got the LED on programmer Green but the Error occur anyway when start iMPACT
Now the LED is OFF always.
I use USB cable
I go the Info:
 Linux release = 4.13.0-39-generic.
INFO:Cse - The fxload application is not installed. This application is required when using the Platform Cable USB. This warning should be ignored if you are using the Parallel Cable III or Parallel Cable IV. Please download and install the fxload-2002_04_11 package. Note that root access is required to perform the installation.
Question ?
Dose the old
really working on Ubuntu 16.04 ???
Best Regards
Olle Welin
