iMPACT's Batch mode
I want to use impact batch mode command line to program the bit file. The content of the cmd file(test.cmd) is below:
setmode –bscan
setcable –p auto
identify
assignfile –p 1 –file design.bit
program –p 1
quit
      I run the above command one by one, there is not any problem. while I run the command "impact -batch test.cmd", it returns the following error message: ERROR:iMPACT:335 - Invalid command, 锘縮etmode
      Is there any file format to comply with?
@viserver629 This should work. There seems to be special character getting inserted when you did copy/paste in the editor.
Attached script should run at your end without any problem.
-Pratham
@viserver629 Did that helped? Let us know if you are still having issues.
-Pratham
