missing ILA slot
Version: Vivado 2017.4
The ILA slot is missing. There are no data signals shown in the waveform viewer.
- ILA is configured as DATA AND TRIGGER
- ILA trigger are available and can be armed
- in Vivado Dashboard Options, Waveform is SET
- ILA is clocked from a clean clock signal, free running and within allowed ranges
- Bitstream and Debug probes files are loaded and matching
- ILA slot is in fact synthesised
I see no reason why it would be missing in the Waveform viewer - what could be the reason?
Tags (3)
Re: missing ILA slot
Hi @jack.roundhouse,
If you click on the "+'" button on the top of the screen (close to the magnifying glass) does it show any signals available for you to add?
If not, please open your Synthesized Design and run the command write_debug_probes C:/Data/designProbes.ltx then open this file and check if the probes you had selected are correctly named there.
If the file looks fine, please reprogram the FPGA with the bitstream you already had and this new LTX file.
Please let us know if that helps.
Andre Guerrero
Product Applications Engineer
Andre Guerrero
