primitive question: WARNING:ProjectMgmt - ... x.tfi is missing.
We get the following message:
WARNING:ProjectMgmt - File G:/A2C0/x/mig38/mig_38/user_design/par/blk_mem_gen_v6_2.tfi is missing.
The file was once deleted by hand and is no more needed. How do you avoid this message?
Best regards
Josef Sedlacek
Re: primitive question: WARNING:ProjectMgmt - ... x.tfi is missing.
There is a file somewhere that keeps track of everything in your project folder.
I get a ton of these and as my project happens to be on the network (and sometimes on a remote network) it is really taking a toll on both the PC performance overall and network performance in particular.
Can someone point out the file where the list is kept and / or a way to turn off this tracker or at least configure how frequently it tries to check for updates to the project?
Here's something to try (at least it seems hopeful in v14.2 ISE that I am using): Project->Cleanup Project Files (be sure to check that it won't be deleting any files you actually want to keep). Also Project -> Disable Hierarchy Reparsing looks promising, but may have the side-effect of requiring manual hierarchy reparsing whenever any of your source changes and you must re-build.
Hey.. I am new to floating point IP core. I have created top.vhd file. but the problem is I am getting result as all zeros. actually it should be addition of a and b. please please help me
