prohibit chipscope download
Hi!
My problem is i wish to use a board where UART and JTAG are on the same USB cable. I would like to create a security applicaton, and store a hardwired key in the FPGA. My question is if it is theoretically possible to read this key from the FPGA by downloading Chipscope through partial reconfiguration? And if i can prohibit that anyhow, like encrypting the bitstream, or in worst case i just cut the JTAG wire on the board when finished?
Thanx for the answer in advance!
Re: prohibit chipscope download
Hey @feketebv
Check out XAPP1084, specifically the section starting at page 9 about disabling JTAG.
Hope this helps,
Herbert
Hey @feketebv
Hope this helps,
Herbert
