"greater than" trigger of ILA
Hello, I used ILA to capture some data.
I'm trying to use "probe29[31:0]" as a trigger with "greater than" condition. But, when I run this trigger, Vivado reports the error like below. Do you know why?
"[Labtools 27-3258] Due to ILA core feature implementation, probes which do not match the complete ILA core probe port from MSB to LSB may only use operator 'eq' or 'neq'.
hw_ila 'hw_ila_1' hw_probe 'i_cputop/g_CPUbridge_VirtualJTAG.i_IPG1_VirtualJtag/delay_cnt[31:0]' with MAP property 'probe29[31:0]' uses operator 'gt' in compare value 'gt32'h0000_0010'."
Scholar dpaul24
Re: "greater than" trigger of ILA
@softwind555,
Are you setting the complete 32 bit value for probe29[31:0]?
FPGA enthusiast!
All PMs will be ignored
Hello, @dpaul24
Yes. Please find the code slice below:
	COMPONENT ila_virtual_jtag
PORT (
	clk : IN STD_LOGIC;
	probe0 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe1 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe2 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe3 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe4 : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
	probe5 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe6 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe7 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe8 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe9 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe10 : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
	probe11 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe12 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe13 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe14 : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
	probe15 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe16 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe17 : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
	probe18 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe19 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe20 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe21 : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
	probe22 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe23 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe24 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe25 : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
	probe26 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe27 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe28 : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
	probe29 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	probe30 : IN STD_LOGIC_VECTOR(31 DOWNTO 0)
END COMPONENT  ;
signal delay_cnt :			unsigned(31 downto 0) := (others=>'0');
i1_ila_virtual_jtag : ila_virtual_jtag
	PORT MAP (
		clk => CPU_Clk,
		probe0(0) => Reset,
		probe1 => iCPU_Address,
		probe2 => iCPU_WData,
		probe3(0) => iCPU_Write,
		probe4 => (others => '1'),
		probe5(0) => iCPU_RRequest,
		probe6 => CPU_RData,
		probe7(0) => CPU_RAck,
		probe8(0) => CPU_Int,
		probe9 => AWADDR,
		probe10 => AWPROT,
		probe11 => AWVALID,
		probe12 => AWREADY,
		probe13 => WDATA,
		probe14 => WSTRB,
		probe15 => WVALID,
		probe16 => WREADY,
		probe17 => BRESP,
		probe18 => BVALID,
		probe19 => BREADY,
		probe20 => ARADDR,
		probe21 => ARPROT,
		probe22 => ARVALID,
		probe23 => ARREADY,
		probe24 => RDATA,
		probe25 => RRESP,
		probe26 => RVALID,
		probe27 => RREADY,
		probe28 => (others => '1'),
		probe29 => std_logic_vector(delay_cnt),
		probe30 => std_logic_vector(delay_cnt_max)
Visitor iprop1
I found a potential solution - don't know if it will help you or not.
Here is the message I was getting:
hw_ila 'hw_ila_1' hw_probe 'XXXXXX[63:0]' with MAP property 'probe13[63:0]' uses operator 'gt' in compare value 'gt64'h0000_0000_0000_0004'.
What I found out was that my xdc file had the bus as {XXXXXX[0],XXXXXX[1],......,XXXXXX[63]}
I opened my LTX file and noticed that my bus was ordered as XXXXXX[63],XXXXXXX[62], .... XXXXXX[0].
Now, both of these files were never modified by me; both are autogenerated by Vivado.  One during the setup debug step (as a save to the constraints file) and the other when the bitstream is created.
I hand edited the LTX to reverse the bits so that it now was XXXXXX[0],XXXXXX[1]....XXXXXX[63] to match how my xdc was, and now, I can now do > and < operations!
I'm using 2018.2 and the my chipscope worked for several weeks with no issues, and then all of a sudden, I started getting the error I posted.  I tried closing Vivado and reopening as another post suggested, but that did not help.  I tried many things until I did the above file edit.
Good luck - and I hope this helps
Hiren
