zaid786
refresh_hw_device : invalid vector<T> subscript
Hardware manager of vivado 2016.2 , I get this error message after a resfresh device command:
refresh_hw_device [lindex [get_hw_devices] 0]
and hardware window get empty (no more server and device shown).
Any idea ??
Thanks a lot
arpansur
Hi @zaid786,
Can you try reducing JTAG frequency and check again?
Arpan
pligroup
I am facing the same problem. Everything worked fine before and then it came all of a sudden.
I've tried to reduce the frequency of the JTAG but no the problem it still there.
Can anyone help?
dpaul24
I am getting this message from today!
Windows 7 Pro + Vivado 2017.2
The 4 ILA cores inside are being detected properly.
Any hints why this is happening?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
iguo
Check if the JTAG frequency is higher than dbg_hub clock frequency. If it is, lowers it down.
Besides, do not connect multiple cable to PC at the same time.
ceerqingting_ld
hi,I got the same error with you,have you get any answer about it?
kwame.kyere
Hallo,
i am having similar issues with my ILA as well.
Pls are there any known Solutions to this?
Best regards,
Kwame
kwame.kyere
Problem solved after reducing the ILA(JTAG) clock as mentioned previously in this thread.
prevankar76
I tried reducing the JTAG clock frequency as indicated, but did not help, still get the following error
INFO: [Labtools 27-2302] Device xc7vx690t (JTAG device index = 0) is programmed with a design that has 1 ILA core(s).
There was no additional information in the error message to debug as well.
kwame.kyere
Hi , my question is how fast is your ILA clock? What is the width of your probe?
Perhaps you could try this:
Workaround: if an eFuse programing error occurs, the user needs to manually execute refresh_hw_device to update all the device settings.
It was a suggestion from a similar thread. I havent tried it out myself.
Best regards
