04-13-2017 08:22 AM
Using Vivado 2015.4
phase 1 :
phase 2:
Now : somewhere during bitstream generation (looks like implementation phase), I get a pop-up with a critical message : [Common 17-162] Invalid option specified for '-nets'. [/path_to_my_xdc:171]
In the log file I found this :
Parsing XDC File [/home/zynqdev/Zynq/2015_4/drfa/zynqsnap/Vivado/src/constraints/mark_debug.xdc] WARNING: [Vivado 12-507] No nets matched 'u_ila_0_clk_out1'. [/home/zynqdev/Zynq/2015_4/drfa/zynqsnap/Vivado/src/constraints/mark_debug.xdc:171] CRITICAL WARNING: [Common 17-162] Invalid option value specified for '-nets'. [/home/zynqdev/Zynq/2015_4/drfa/zynqsnap/Vivado/src/constraints/mark_debug.xdc:171] Finished Parsing XDC File [/home/zynqdev/Zynq/2015_4/drfa/zynqsnap/Vivado/src/constraints/mark_debug.xdc]
line 171 of the mark_debug.xdc contains (complete file attached)
connect_debug_port dbg_hub/clk [get_nets u_ila_0_clk_out1]
However, bitstream generation completes ok, and the ILA has the signals added.
This issue seems to appear systematically, each time I 're-edit' the setup debug configuration ...should I worry about this? Or am I doing something wrong? Should I clear the contents of the .xdc file before I save the synthesised design?
Also, do I need to re-run synthesis after these debug probe changes, or can I force synthesis 'up-to-date'?
04-25-2017 04:35 AM - edited 04-25-2017 04:41 AM
@arpansur, after running into some more errors during 'incremental set up debug cycles', I found the cause. Here are the critical warnings I get at the moment :
1) the first 2 warnings refer to constraints in the very beginning of the xdc file, that try to connect u_ila_x_clk_out1 to the dbg_hub/clk. But they are put in the xdc file (by Vivado's setup debug wizard) before the actual 'create_debug_core' statement :
connect_debug_port dbg_hub/clk [get_nets u_ila_0_clk_out1] connect_debug_port dbg_hub/clk [get_nets u_ila_0_0_clk_out1] create_debug_core u_ila_0_0 ila set_property ALL_PROBE_SAME_MU true [get_debug_cores u_ila_0_0] set_property ALL_PROBE_SAME_MU_CNT 1 [get_debug_cores u_ila_0_0]
also, the very first line tries to connects u_ila_0_clk_out1, while the debug core is named u_ila_0_0. So this looks like a 'leftover' from some previous debug core.
So I commented out the first 2 lines, this clears the first 2 critical warnings
2) the third warning points to the very last line in the xdc file :
... connect_debug_port u_ila_0_0/probe50 [get_nets [list design_1_i/snap_SNAP_IO_27_io_wr_full]] set_property C_CLK_INPUT_FREQ_HZ 300000000 [get_debug_cores dbg_hub] set_property C_ENABLE_CLK_DIVIDER false [get_debug_cores dbg_hub] set_property C_USER_SCAN_CHAIN 1 [get_debug_cores dbg_hub] connect_debug_port dbg_hub/clk [get_nets u_ila_0_clk_out1]
again here is a left-over constraint from a previous debug setup, as u_ila_0_clk_out1 does not exist, it should be u_ila_0_0_clk_out1
so this looks like some bugs in Vivado, having difficulties when you re-run the 'set up debug wizard' a few times.
so I modified the last line to u_ila_0_0_clk_out1, and this clears the third critical warning !
note that bitstream generation was always successful, and the ILA operated correctly too, despite the critical warnings - so Vivado did connect the clock anyway, even with the error in the very last line of the xdc file... kind a strange ...
04-18-2017 02:58 AM
Hi @ronnywebers,
As long as clock connectivity of debug hub is okay you should not worry.
