seeing words instead of bits in in chipscope analyzers
hi all,
is it possible to see the data in form of words on chipscope analyzer?(note that I have 16 and 64- bit data)
I have tried but what I get is only the bits which I have to translate myself if I need to make them into words which is very hectic and time consuming...
I mean what i get is like the result below images...althought they both are 4 bit data words.
any alternate idea?
Scholar markcurry
Re: seeing words instead of bits in in chipscope analyzers
Over in the Signals Pane on the left side: Select Data Port.  Select your group of signals.  Right click -> Move to Bus -> New Bus.  Then name your bus as you wish.
In the other panes, you can switch your bus-radix to hex, decimal, etc...
Mark
Scholar markcurry
Mark
