set a register in ChipScope?
Hi all,
I've been told it's possible to set register values in Chipscope after the FPGA is programmed, but the guy who told me this was unable to explain how.  Is that possible?  Can anyone direct me?
Rick
Re: set a register in ChipScope?
You can use a Chipscope "VIO" block to control registers.
DS284
Mark
DS284
Mark
Amazing!  That will be very useful.
