unable to programme the spartan 3A device
Dear sir,
I am using Spartan 3A DSP xilinx FPGA, Device XC3SD1800A-FGG676AgQ1313 and it is configuring using a master serial mode using a XCF08P. But when I am going to download simple programme , I found that in JTAG chain only one device (xc3sd1800a) is present and XCF08P is missing.  But when I am going to dounload the program in the xc3sd1800a I am founding the programme failed message and cannot download it. The details message are attached here with. Please give me the solution. Thanking You.
With Regards
Pallab Kumar Nath
PhD student at IIT Kharagpur.
09830552910
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable connection failed.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
Driver file xusb_emb.sys found.
Driver version: src=1029, dest=1029.
Cable PID = 0008.
Max current requested during enumeration is 300 mA.
Type = 0x0005.
write (count, cmdBuffer, dataBuffer) failed C0000004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 2301.
File version of C:/Xilinx10.1/10.1/ISE/data/xusb_xp2.hex = 2400.
Firmware hex file version = 2400.
Downloading C:/Xilinx10.1/10.1/ISE/data/xusb_xp2.hex.
Downloaded firmware version = 2400.
Type = 0x0005.
ESN option: 00001631BCE401.
PLD file version = 2007h.
PLD version = 200Dh.
PROGRESS_END - End Operation.
Elapsed time = 2 sec.
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
Identifying chain contents ....'1': : Manufacturer's ID =Xilinx xc3sd1800a, Version : 0
INFO:iMPACT:1777 -
Reading C:/Xilinx10.1/10.1/ISE/spartan3adsp/data/xc3sd1800a.bsd...
INFO:iMPACT:501 - '1': Added Device xc3sd1800a successfully.
done.
Elapsed time = 1 sec.
// *** BATCH CMD : identifyMPM
// *** BATCH CMD : assignFile -p 1 -file "E:/cntr/cntr.bit"
'1': Loading file 'E:/cntr/cntr.bit' ...
done.
INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
// *** BATCH CMD : Program -p 1
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1': Device IDCODE : 00001111111111111111111111111110
INFO:iMPACT:1579 - '1': Expected IDCODE: 00000011100001000000000010010011
Elapsed time = 0 sec.
Community Manager
Community Manager
Re: unable to programme the spartan 3A device
Please reduce the cable speed and see if it helps in resolving the issue.
You can also try a different JTAG cable to see if the JTAG cable has got damaged.
Krishna
Moving to correct board.
Thanks,Vijay
The log file is showing the IDCODE mismatching.
The following Answer http://www.xilinx.com/support/answers/13529.html address the issues related to IDCODE mismatch.
I see from the log file that you are using 10.1 impact, can you switch to 14.7 impact and see if this helps.
--Krishna
