understanding the commands
create_debug_core u_ila_3 ila
set_property ALL_PROBE_SAME_MU true [get_debug_cores u_ila_3]
set_property ALL_PROBE_SAME_MU_CNT 1 [get_debug_cores u_ila_3]
set_property C_ADV_TRIGGER false [get_debug_cores u_ila_3]
set_property C_DATA_DEPTH 1024 [get_debug_cores u_ila_3]
set_property C_EN_STRG_QUAL false [get_debug_cores u_ila_3]
set_property C_INPUT_PIPE_STAGES 0 [get_debug_cores u_ila_3]
set_property C_TRIGIN_EN false [get_debug_cores u_ila_3]
set_property C_TRIGOUT_EN false [get_debug_cores u_ila_3]
set_property port_width 1 [get_debug_ports u_ila_3/clk]
connect_debug_port u_ila_3/clk [get_nets [list {u_ila_3_rxusrclk_in[0]}]]
set_property PROBE_TYPE DATA_AND_TRIGGER [get_debug_ports u_ila_3/probe0]
set_property port_width 1 [get_debug_ports u_ila_3/probe0]
connect_debug_port u_ila_3/probe0 [get_nets [list uhdsdi_demo/sdi_4ch_rxtx/link_status_out_4_3]]
what are these commands used for ?
Regards.
Re: understanding the commands
Hi @veekshitha
These  constraints are equivalent for ILA IP configurations.
Example set_property C_DATA_DEPTH 1024 [get_debug_cores u_ila_3]  is equivalent command for  Sample data depth in the IP.
These constarints are useful to change the IP configuration affter post synthesis/post implementation so that you dont need to reconfigure the IP
Hi @veekshitha
