070411209
vivado ILA waveform no content
Do you konw what is problem of waveform, Trigger window have signal ,but Waveform is nothing, what's the problem?
vsrunga
@070411209
Have you added the siganls and were you able to see them earlier and they disappeared now?
Can you close the hw_ila1 window, reopen it and check if you can see any signals?
If not please click on the "+" button and manually add the signals.
Also click on trigger immediate and recheck
-Vanitha
tomasz.janicki.tj
hmmm, as seen in the pic above. there is no '+' button
got the same problem
only closing and opening up the 'program and debug' (aka. refreshing) helps
my tcl console:
open_hw_target
INFO: [Labtoolstcl 44-466] Opening hw_target 192.168.18.115:3121/xilinx_tcf/Xilinx/000014d221db01
set_property PROGRAM.FILE {/home/tomasz.janicki/ZYNQ/PicoZed_2015.4_Avnet/pico-hardware/hardware/PZ7030_20154_01/PZ7030_20154_01.runs/impl_1/TOP.bit} [lindex [get_hw_devices] 1]
set_property PROBES.FILE {/home/tomasz.janicki/ZYNQ/PicoZed_2015.4_Avnet/pico-hardware/hardware/PZ7030_20154_01/PZ7030_20154_01.runs/impl_1/debug_nets.ltx} [lindex [get_hw_devices] 1]
current_hw_device [lindex [get_hw_devices] 1]
refresh_hw_device [lindex [get_hw_devices] 1]
INFO: [Labtools 27-2302] Device xc7z030 (JTAG device index = 1) is programmed with a design that has 3 ILA core(s).
refresh_hw_device: Time (s): cpu = 00:00:07 ; elapsed = 00:00:06 . Memory (MB): peak = 7803.621 ; gain = 0.000 ; free physical = 2760 ; free virtual = 8484
display_hw_ila_data [ get_hw_ila_data hw_ila_data_1 -of_objects [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"wrf_snk_in_ila_inst"}]]
WARNING: Simulation object gtp_int_inst/gtp_rx_data was not found in the design.
WARNING: Simulation object gtp_int_inst/gtp_rx_enc_err was not found in the design.
WARNING: Simulation object gtp_int_inst/gtp_rx_k was not found in the design.
display_hw_ila_data [ get_hw_ila_data hw_ila_data_2 -of_objects [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"wrf_src_in_ila_inst"}]]
display_hw_ila_data [ get_hw_ila_data hw_ila_data_3 -of_objects [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}]]
WARNING: Simulation object U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/src_fab_o[error]_i_4_n_0 was not found in the design.
WARNING: Simulation object U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/src_fab_o[error]_i_8_n_0 was not found in the design.
set_property NAME.CUSTOM mru [get_hw_probes {U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/regs_i[rfcr_mru_o]} -of_objects [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}]]
set_property NAME.SELECT custom [get_hw_probes {U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/regs_i[rfcr_mru_o]} -of_objects [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}]]
close_hw
open_hw
connect_hw_server -url 192.168.18.115:3121
INFO: [Labtools 27-2285] Connecting to hw_server url TCP:192.168.18.115:3121
current_hw_target [get_hw_targets */xilinx_tcf/Xilinx/000014d221db01]
set_property PARAM.FREQUENCY 12000000 [get_hw_targets */xilinx_tcf/Xilinx/000014d221db01]
open_hw_target
refresh_hw_device: Time (s): cpu = 00:00:06 ; elapsed = 00:00:06 . Memory (MB): peak = 7803.621 ; gain = 0.000 ; free physical = 2760 ; free virtual = 8485
run_hw_ila [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}] -trigger_now
INFO: [Labtools 27-1964] The ILA core 'hw_ila_3' trigger was armed at 2016-May-11 07:45:59
wait_on_hw_ila [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}]
display_hw_ila_data [upload_hw_ila_data [get_hw_ilas -of_objects [get_hw_devices xc7z030_1] -filter {CELL_NAME=~"u_ila_0"}]]
INFO: [Labtools 27-1966] The ILA core 'hw_ila_3' triggered at 2016-May-11 07:45:59
add_wave -into {hw_ila_data_3.wcfg} -radix hex {U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/snk_dreq_o}
set_property NAME.CUSTOM dreq_o [get_hw_probes U_WR_CORE/WRPC/U_Endpoint/U_Wrapped_Endpoint/U_Rx_Path/U_crc_size_checker/snk_dreq_o]
close_hw
open_hw
open_hw_target
refresh_hw_device: Time (s): cpu = 00:00:06 ; elapsed = 00:00:06 . Memory (MB): peak = 7803.621 ; gain = 0.000 ; free physical = 2758 ; free virtual = 8484
after the 3rd time my previously set-up content appeared.
T
tomasz.janicki.tj
follow-up question
where/what file to edit in order to modify waveform signals/groups/buses/etc outside of the gui?
then I would like to add that file to the 'Program and debug' session
the only file (Id not dare to edit) is debug_nets.ltx -  but it is not what Im after really
it was possible in ISE :/
T
cbhiskp
I see the same behaviour still in 2017.4.
Flashing a new bitfile with changed LTX file -> "no content".
Closing and reopening "Program and Debug" -> works again.
Please fix?
vitali_sh
Same behaviour in 2018.2.
Wasted many hours struggling with empty window in the Debugger till found this discussion - thanks!
Probably this is a feature, not a bug.
profan
You may try to set JTAG speed lower then ILA clock speed. In my case it helped
liu_chang
Thank you!
Slow the speed of JTAG can solve this problem.
