vivado verilog wire problem
While I'm doing uart communication on a board,in my program I wire a "rx_done"signal  which measn the fpga receives a byte sucessfully, it will cause a positive edge.And in other modules,I use "rx_done”as a sentitive singal in an always struct.
Smulation is ok,but on the board it dosen't work,so I want to ask how I can constraint "rx_done" like a clock wire,is this the solution to this problem?
Re: vivado verilog wire problem
Sounds like Vivado synthesis is optimizing the signal away.  Are you routing this signal to a top-level I/O port?  That should preserve that net from being optimized away during synthesis.
You can also preserve the net by providing appropriate constraints.  Refer to the section "Creating Synthesis Constraints" in UG949.
why do you think this signal is the problem in the real system ? Even if it does not happen in the real chip that is not likely to be because the tools are chucking it away,
General debug questions,
What is the chip, OS and versions your using ?
Can you post your constraints as an attachment please ?
Can you post your code as an attachment please ?
