where can I change the value of " JTAG_CHAIN attribute"?
回复: where can I change the value of " JTAG_CHAIN attribute"?
I want to use the "VIO" and "CDC" in the same time, but Somebody telled me that "The value of " JTAG_CHAIN attribute "must be setted to 2"
ERROR:PhysDesignRules:1683 - Unsupported programming for BSCAN block and JTAG_CHAIN attribute value 1. The BSCAN componentmyibert/U0/U_IBERT_CORE/U_XSDB_MSTR/U_VHD_CHIPSCOPE_ICON2XSDB_MSTRBR/U_ICON_INTERFACE
/U_ICON_IFACE_ICON/U_ICON/U_ICON/I_YES_BSCAN.U_BS/I_V6.ISYN.I_USE_SOFTBSCAN_EQ0.U_BS has placement which requires the JTAG_CHAIN attribute to be set to the value 2. The JTAG_CHAIN attribute must be changed or the programming for the BSCAN block must be moved to alocation corresponding to the JTAG_CHAIN attribute setting.
where can I change the value of  " JTAG_CHAIN attribute"???
hi @wandtdk
Please check if this below AR helps.
http://www.xilinx.com/support/answers/50436.html
