why chipscope analyzer showing double increment in counter value
hi all
I have just made  a simple 1 number counter as follows...
process(clk_s, rst)
begin
if(rst = '1') then
	cnt_s <= (others =>'0');
elsif(rising_edge(clk_s)) then
	cnt_s <= cnt_s + '1';
end if;
end process;
 now see the image which shows the counter increment in double values...
Scholar markcurry
Re: why chipscope analyzer showing double increment in counter value
I can think of two possibilities:
What clock are you sampling with?
You have a bitshift somewhere - either where you hookup to chipscope, or inside the analyzer itself where you grouped selected wires onto the full bus.
Mark
previously I was using different clock 100 MHz but now I am using 12 MHz clock for purpose of testing only since I am using chispcope acquiring frequency 12 MHz as well.
I cannot understand your ideas, can you explain in a bit detail.
Also, paste your complete code and the chipscope connections you have made along with the settings to check.
Debraj
