Axi master to axi lite interface question
I've got a desing in vivado with a standar library  'axi_timer' IP, which I wan't to interface it from another custom IP generated by HLS using a axi master.
I've got the function:
void my_function(short input1, short input2, int times[3])
Where I'd like to write the times[i] values to a specific register addresses in the axi_timer IP. (Instead using the PS)
For instance: write 'times[0]' value to (XPAR_AXI_TIMER_0_BASEADDR + 0x04) address of axi_timer IP
How is possible to do? is there any example or app note?
Teacher muzaffer
Re: Axi master to axi lite interface question
just generate an axi master interface; ie just say
myfunc(int* axi_timer, int count, ...) {
  *(axi_timer + count_offset) = count;
In the block diagram you can connect your master port to the slave port of the axi_timer at which time the BD editor will insert the necessary interconnect to make it work.
Teacher muzaffer
Thanks Muzaffer for your reply, I guess with the right offset, I could write as well in the axi slave configuration registers, I'll try that.
Best regards.
Teacher muzaffer
I have implemented many PL masters which share responsibility of some IP with the PS. Just add a 2 slave 1 master interconnect and use the PS & PL masters to connect to the slave ports.
