Visitor srkj990
CODING IN VIVADO HLS DESIGN
How to write c/cpp program for a verilog code for vivado hls design to create a new custom ip block
Re: CODING IN VIVADO HLS DESIGN
Hi @srkj990 ,
Check this tutorial. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug871-vivado-high-level-synthesis-tutorial.pdf
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Scholar u4223374
Create a HLS project. Add a source file called "top.cpp" (you can call it anything, but putting for an example project having a top function in a file called top.cpp seems sensible). Insert this code:
void a(){}
Now go Project -> Project Settings, click the Synthesis section, and in the Top Function box put "a". Then:
Click "OK" to close the window.
Click the C Synthesis button to build your code
Click on the Export RTL button
Click "OK" to export the IP
All done! You now have a HLS IP core.
