Can Vivado 2016.3 support string for file IO?
Hi all,
Can Vivado 2016.3 support string for file IO just like below?
#include <string>
int main ()
  string fa = "C://a.txt";
  ifstream fa_strm (fa);
Re: Can Vivado 2016.3 support string for file IO?
hi @araongao2015
the code you show is used in C TB so you can do whatever you want as long as it's correct code, for example it does compile, does not segfault at runtime etc. this code is note used for C synthesis.
however you cannot use this exact same code for C synthesis.. an RTL IP doesn't cannot do anything with your file "C://a.txt" it doesn't make sense to expect to read a file from a hard drive from an FPGA, as-is.
I hope this helps.
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Hi @herver,
Thank you. Actually when I try to use it in C++ testbench, it shows an error.
But if I use below code, the testbench can run well.
char *fp = "C://a.dat";
That's why I guess Vivado 2016.3 does not support string as a valid file type.
